PVC covered rubber twin | on ElectriciansForums
Discuss PVC covered rubber twin in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jimmer
Is there a name for this type of cable? I've come across the black rubber cables before but this has a grey pvc type of sheath on a rubber cable. The insulation resistance reading was just above 2 M.ohms, but the rubber conductors were in good condition. What advice should i be giving the customer?
Any help much appreciated
ye, tell em to have it rewired, in actual fact un disturbed the rubber cable would last, but i would advise em thats the bottom line, its really had its day and needs replacing.
I would definately second that!
The cables are obviously very old and very close to losing all their insulation values, (just over 2M.ohms) so its only going to be a matter of time before a problem will occur.
Better to advise on the safe side to the customer. I am sure that when you advise them, with poor insulation there is the risk of fires and electric shock they might take a different view to the costs involved in bringing the installation up to standard.
Reply to PVC covered rubber twin in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
