PVC mini trunking cutters, your thoughts, are they any good@ | on ElectriciansForums
Discuss PVC mini trunking cutters, your thoughts, are they any good@ in the Electrical Tools and Products area at ElectriciansForums.net
I have tried several variations of mini trunk cutters
Some good some not so
Hi All
Saw some of these cutters advertised on the TLC site. Anybody tried them?
Thanks in advance
Is there meant to be a link or pic with this mate?
[ElectriciansForums.net] PVC mini trunking cutters, your thoughts, are they any good@
Might just be me but they seem a bit pricey.....I'm sure they'd be handy because they can cut a 45 degree mitre but the jaw only opens to 35 mm so only good for mini trunking.
Hi All
Thanks in advance
I used to be a glazer many moons ago, but as I'm a spark now I use a tool from then an it's by far the best for trunking, it has angles marked out and can create notches etc. They are miter snips, but if you get a set don't go cheap and steer well clear of the stanley blade kind, Lowe miter snips are the only ones worth getting and are approx 20 great British pesos.
Hi All
Thanks in advance
I used to be a glazer many moons ago, but as I'm a spark now I use a tool from then an it's by far the best for trunking, it has angles marked out and can create notches etc. They are miter snips, but if you get a set don't go cheap and steer well clear of the stanley blade kind, Lowe miter snips are the only ones worth getting and are approx 20 great British pesos. Link to these provided but if you check a local window supplier or plastics supplier you will get them cheaper.
I hope this helps, but once you get a set you'll use them for far more, blades can be removed and sharpened or replaced. I used these everyday for atleast 5 years, sharpened twice and still going.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Strangely enough I done glazing many moons ago as well and have a pair of these, But must admit never used them on mini trunking as always relied on the trusty old hacksaw
I've been using the red CK ratcheting cutters for a little while now with no problems. Yes obviously you can use a hacksaw for a very similar result, however when doing a lot of trunking work the cutters save time and a lot of mess!
Reply to PVC mini trunking cutters, your thoughts, are they any good@ in the Electrical Tools and Products area at ElectriciansForums.net
It's galvanised and provided you coat any cut edges with galv spray there should be no signs of undue corrosion any time soon. Galv trunking...
nicebutdim
N
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
