PVC or XLPE cable | on ElectriciansForums
Discuss PVC or XLPE cable in the Australia area at ElectriciansForums.net
R
roukel01
Morning all
Is there a way to tell whether a cable is standard PVC or XLPE??
All that is stamped on the cable is "BICC Group 1981 600/1000V Electric Cable"
Its a 50mm 4 core SWA cable, looking at current carrying tables, it seems there is a big difference between the two types of cable and I could do with knowing which it is.
Thanks chaps.
Thanks chaps.
The only reason the current carrying capacity is higher is due to the fact that XLPE insulation supports a higher conductor temperature. However, you cannot use the higher current carrying capacity if the accessories do not support these higher temperatures.
No but you can use a smaller sized cable.
Only if the accessories you terminate it into are rated to 90°C!
It's the same conductor material (occasionally it's annealed differently giving a different resistivity), it's just allowed to get hotter without compromising the insulation. The extra 20° adds another 20-30% to the capacity.
We're getting off the subject. Anyhow, I'm assuming its 70o PVC
Reply to PVC or XLPE cable in the Australia area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
