G
Gardner
Obviously code restricts PVC and twin and earth to 70*C max, but out of curiosity what is the designed temperature rating of the insulation? Just wondering.
Discuss PVC temprature rating in the UK Electrical Forum area at ElectriciansForums.net
There is a buffer zone applied but not much, the integrity of the insulation will breakdown if run at over 70c be it from the conductor or the ambient temp' and is subject to the temp' and the time, and as above its subject to manufacturing processes.
Regardless of cable rating it will b derated to the equipment it is connected to so as most is manufactured to 70c then a 90c cable connected to a standard 70c rated switch gear has to be derated to suit.
Reply to PVC temprature rating in the UK Electrical Forum area at ElectriciansForums.net
