PVC to steel conduit adaptor | on ElectriciansForums
Discuss PVC to steel conduit adaptor in the UK Electrical Forum area at ElectriciansForums.net
A
AshleyW
Hi,
I was just wondering what the best way to connect PVC to steel conduit is? I was thinking PVC male adaptor and a steel conduit coupler?
Cheeeeeeeeeeers :D
Yes you are right, male adaptor will do it or even a small adapt box with the conduit fixed each side. If the metal conduit was used as an earth / secondary earth then put a earth clamp on it and run a single earth cable through a gland on the side of the box to the end destination and terminate appropriatly.
Reply to PVC to steel conduit adaptor in the UK Electrical Forum area at ElectriciansForums.net
I have a customer with an insulated aluminum patio cover featuring two ceiling fans. On the roof, there are two PVC junction boxes connected by...
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
