Pvc v rubber | on ElectriciansForums
Discuss Pvc v rubber in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I suppose it depends upon the level of incontinence involved. I'd recommend tight leg holes and a drainage point. All sorted.
Reply to Pvc v rubber in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Hello Everyone. I'm surprised this subject does not get much attention. 'The elephant in the room' I refer to is the 'new rubber'. On new...
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
