T
tuffcookie
Hi..I am currently making a funky light fitting using pyro cable..I have a 300watt dimmable low voltage teroidal tranformer..ffrom this runs a 2m length if 1mm pvc flex which feeds a connection box..from connection box I have 12 lengths of pyro..each length has a 20watt lv lamp..my problem is..the pvc flex is getting way to hot!!!! Do I need to run more cables?? Any help would be great )
