alindefaugh
First I will pose the question so you don't need to read the rest if you don't want to:
What if any are the possibilities that a pretty long RG6 coaxial cable (cable TV - about 11 meters inside apartment ) would interfere in any way with a PC + 144Hz monitor that is in very close proximity(1.5-2 meters)?
If any, is there any way to measure the effect (using a multimeter if the cable caries an unwanted electrical charge etc) o rule out the effect / effects?
The rest of the post is more details about the setup and why I ask.
I have a rather long RG6 coaxial cable (goes into my TV). I'd say in the room in question it's about 3 meters (that is required to reach the TV) + about 5-6 meters that was extra + maybe 2-3 meters in the hallway (before entering the room).
I coiled the extra 5-6 meters and it was sitting behind / near TV
Now I will describe the issue I suppose I am facing: either a very very very slim monitor delay - altered frame timing / peripherals delay - mouse / controller having it's timing affected / general system delay (I don't think so but I am not an expert can't rule that out I don't expect the GPU or CPU would be hindered)
I was rather unsatisfied with the general mouse feel (hard to describe and observe so we can leave that aside).
On top of that I sometimes use a wireless game pad(supports wired as well trough a mcro-usb and wired behaves the same way) and this one is easy to feel when something is wrong. I test it in a game that requires intensive precise and constant direction change of the controller left stick and you can tell right away that it feels different. If I would try to describe what is wrong it's like this: say I am doing a 60 degree left stick motion with the same speed but what ends up happening is 40 degree is at a speed then 5 degree is slower and the rest is accelerated to compensate.
Well at some point I grabbed the coiled cable and put it on the desk so now it sits in front of the monitor on the same desk that holds the controller. The controller became a mess in the game (again I am not sure if it's the controller or the monitor etc) , it just felt completely unreliable and random timings. Then I cut the extra 5-6 meters and I remove the ending connector (which looked like it was crushing the cable actually ) and now the cable is no longer coiled and I didn't install yet another connector.
I just have to say it's really really improved... So this is why the question at the start of the post, I want to understand if this is possible and if yes what more could I do about the rest of the cable
Thanks for reading this and if it's stupid sorry, it was worth the risk of writing something stupid in hope of fixing a rather annoying issue
- TL;DR
- What if any are the possibilities that a pretty long RG6 coaxial cable (cable TV - about 11 meters inside apartment ) would interfere in any way with a PC + 144Hz monitor that is in very close proximity(1.5-2 meters)?
