Question about wiring | on ElectriciansForums
Discuss Question about wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Y
Yvens
What size wire do you need for a 600 amp transformer to a 500 amp bus mean disconnect?
Also, how can I wire a fire alarm in a first story building? Are there any plans online? How can I wire in the panel control? How can I address the alarm?
depends on too many factors to tell you here. look at your course notes, to remind yourself about cable sizing, and as for the fire alarms, look at the instructions.
Good luck,
John
Reply to Question about wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
