This is an actual job and not from a past paper etc. It is a place I do a bit of work for.
The warehouse manager asked me to make up a 50 meter extension lead for his pressure jet wash machine to be used to clean the path leading to the showroom entrance, car park and the lorries. The pressure washer will use a max of 13A and will be plugged into a Blue 230V commando outlet which is protected by a 16A MCB, commando socket is wired in 4mm singles in galv conduit about 4m from the DB so volt drop/cable size/MCB is not a problem and it is on its own circuit. (more info than what is needed but I'm painting a picture for you lol).
Q:- What type of cable would you used and why?
Q:- What CSA of cable would you use and why?
Q:- Is it necessary to provide rcd/rcbo protection in this situation?
DONT POST UP YOUR ANSWERS. Please pm me your findings to give everyone a chance to see this thread and in a week I will post up the answers. Just have a go at it, I will not take the Mick out of any silly answers (ok I might have a bit of banter ).
This is a good little exercise for you all and it is something different than the exam mock question.
I await your PM's. Better clean out my inbox lol
