Question form filling | on ElectriciansForums
Discuss Question form filling in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
GPack
On some of the certificates it has a heading Main Switch or Circuit Breaker and has the following bits that need to be filled in
BS TYpe........ No. of poles.......... Current rating....... Voltage Rating.........
Location......... Fuse Rating or setting.............
For a normal domestic installation which bit should I be looking at? Would it be the main switch on the consumer Unit, or the main fuse at the cut out?
That refers to the main switch of the installation, be it the 100A main switch of a CU in a domestic situation, or the 600A main isolator in an industrial setting.
The suppliers fuse would come under "primary overcurrent protection" heading.
So in a normal domestic situation where I have a 100A main switch, where it says fuse rating or setting on the form, would I just leave it blank or would I put 100A?
Yes, if the supply is direct from the meter to the CU and it is a standard main switch to BS 60947-3 and you have already recorded the main switch details you put N/A in these sections.
These would be filled in if it was an MCCB used as a main isolator for instance where there are overload settings present.
Reply to Question form filling in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
