Question help (301) | on ElectriciansForums
Discuss Question help (301) in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
B
bob251
Hi I have my 2330-301 coming up and its time I got these formulas I been stuck on out the way could you please help me by working it out and telling me how you done it, I will seriously appreciate it, thanks alot!
The air gap in a conductor is 25mm squared, the flux density is 1.5 T. calculate the total flux.
How many numbers of turns are needed on a transformer if the primary windings are 1000 and the primary and secondary current are 5A and 20A respectively.
A transformer has an output of 12 KVA and a power factor of 0.9. The total losses in the transformer are 600w. What is the effeciency of the transformer?
A transformer takes a load of 50 KVA with an input of 37 KW. What is the total power factor?
A transformer takes a load of 25 KVA at a power factor of 0.8. Calculate the input in KW.
A small heating circuit draws 1.5 KW of power and has an internal resistance of 0.5 ohms. What is the total current?
The resistance of a 230V 3 KW wall mounted heater will be?
If a current of 200 mA flows into a capaciator for 40mS, how much charge will develop in the capaciator?
A medium sized factory has a three phase load of 50 KVA and 30 KVAr, calculate the power factor.
W = BxA = 1.5 x 25 x 25 x 0.0010 = 0.93Wb.
PF = True power / Apparent power = 37000 / 50000 = 0.74
KW = KVA x PF = 25 x 0.8 = 20KW.
I = Sqrt of W/R = 1500sqrt / 0.5 = 54.77A.
R = Vsquared/W = 230squared / 3000 = 17.6ohms.
Theres a few I managed to remember, and now my swede is hurtin.....:(
Upvote 0
just been looking through some of the handouts we got when i was on the course, there is boat loads of them will take me hours to pick some out if i find anything thats any good i will send it to you, pm me your email address and i will send them over
Upvote 0
Thanks alot lenny and phil I just been working through some and I think I cracked the second 1
20/5=4 1000/4= 250 turns (this was a multiple choice question and 250 is one of the awnsers)
Upvote 0
What is the symbol on the calculator for squared I think it is the tick3 or 1.732 but it does not work on these questions?
Upvote 0
I need help again please with this one ( I have been searching the net and my notes im quite stumped)
A 30KW 3 phase delta connected motor has a power factor of 0.86 lagging. Calculate the line current.
A)53.05A
B)62.35A
C)50.35A
D)5.35A
Upvote 0
Reply to Question help (301) in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Electrical Courses
