Question on CAT6 cable | on ElectriciansForums
Discuss Question on CAT6 cable in the UK Electrical Forum area at ElectriciansForums.net
pirate
Supporter
Glasgow
Here is a pic of a CAT6 cable. usual pairs, plastic wrap, foil wrap, draw-cord, plastic separator...and a bare copper wire, which may be cca, i'm not sure...but what is that bare wire used for?
[ElectriciansForums.net] Question on CAT6 cable
It’s for splitting the sheath like that bare wire in a T+E that you just cut off afterwards right? ?
Seriously though I think DPG might be on to something, maybe a way of providing a ground connection for the foil “shielding”.
Edit - it is a drain wire according to this RS Data Sheet
https://docs.rs-online.com/70fc/0900766b8157d0ae.pdf
Mostly network cable is UTP = unscreened twisted pair. This is screened, but to get any benefit from the screen it needs to be earthed, and that is what the drain wire is for.
If you don't believe me, just try connecting to the aluminium foil....
Thanks for all your thoughts, and it is clear that wire is a drain. I don't use this type normally, just the usual UTP. I thought the aluminium screen was just that, a screen, and hadn't thought about its functional connection.
Aha...like a TV coax cable, which IS an aerial!
Theoretically a length of coax would be an ideal transmission line and pass 100% of the signal from the aerial to the TV, with no loss or leakage. Obviously in reality there are losses and small impedance differences. Smith chart anyone?
Reply to Question on CAT6 cable in the UK Electrical Forum area at ElectriciansForums.net
Nail as a fuse works until it doesn't. When you say certain areas what does that mean? If you have been doing it like this for 4 years why the...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
