dogwind
Hi could anyone tell me the correct way to count the number of points served when doing inspection tests, over the years i have seen electricians count lighting circuit points different ways, some have said to just count the light fittings but not the switches eg a single fitting with 2 way light switches would be counted as 1 point,(i would count that as 3) i have also come across the same sort of thing in a kitchen where a switch above worktop would be switching a socket below (for washing machine ect) again i would count this as 2 points as that is 2 connections which i would check on a pir test. Thanks for looking at my thread.
