Question regarding filling in the Schedule of test results. Please Help. | on ElectriciansForums
Discuss Question regarding filling in the Schedule of test results. Please Help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nazoom
Hi
I am trying to fill in a Schedule of test results for a domestic installation. I have one question:
When filling in the the sheet under the section Overcurrent protective device what goes in the "Type" part? Is it acceptable to just say TYPE B or do i have to get the whole number like B 60890?. Then of course I ll mention the rating.
Thanks.
not heard from you for a few weeks nazoom , dont tell me you've been doing your own homework for a change lol ?
record bs60898 in the "type" box
record B32 / C16 etc in the "rating" box.
edit ; ignore the above , all horribly incorrect , facepalm moment.
You need to record both the BS EN number and the type.
There should be separate sections for this information.
If there isn't separate sections for this information, then your schedule doesn't comply with BS7671.
I am filling Schedule of test results for Periodic testing.
So how do I find the number? Do i need to remove each C/B and read the number?
many thanks.
Reply to Question regarding filling in the Schedule of test results. Please Help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
