Not sure if this is right place to ask, but anyway.
Long story short, signed for BT and are getting the equipment delivered tomorrow. This building used to be a pub and has been converted into flats.
BT have run their check and have said there’s definitely a line somewhere in the flat, however I have looked in every room to no avail. It’s possible that the phone point is behind a plasterboard wall somewhere. They said they will get an engineer out to find the line/install one but I might have to wait a couple weeks.
I know it’s just the case of trying to locate where it is in the flat but I don’t know how to approach this. I am am electrician and I know if it wasn’t low voltage then I could probably find it. However as it’s low voltage cable I don’t know the process of finding it, this isn’t really my area of expertise.
Does anyone know an easy way to detect where this would be? If I can find it myself without having to get an engineer out it would be great. Maybe there’s some sort of tool that can detect the cable? Like a cable finder however as I said it’s low voltage so this won’t work
If that line has not been allocated to you, is it likely that it is active? If it is active to someone else you may be doing something illegal.
You have found the line, I would wait for BT to connect it .
Luton
United Kingdom
Trainee Electrician
Question regarding Internet phone line
UK
Uplight99,
ruston,
