G
Guest111
You big softie you,with mine it was a length of plastic conny,lolwith apprentices, i always used to find the best communication tool to be a wet rag applied across the head.
do you reccomend wet or dry apprentices for this test? lolsimple test for end/end. use a megger and an apprentice. croc clip one lead to 1 end of the RFC cable. get the app. to hold the other end in one hand and the other megger lead in the other hand. blast it at 1000v. if he squeals, then you have a circuit
Tony the prob with the OP was it was misleading ?
It came across as a Q but then as a an exam Q ?
The exam could have said test this RFC ? so do we have interconnects ? spurs ? its so vague mate.
Grumpy you ? LMFAO
J
Ulrika I think you're wrong. I reckon if someone came on and said all that I reckon they'd get a lot more help than slating. I'd be very willing to help.If I were a newbie to electrical work, attempting to understand what all these different colours were and why there are so many wires stuffed into small boxes on the wall then I think i would be pretty cagey about declaring my ignorance in case someone splattered my developing confidence across the carpet.....
Having said that I suppose I should come clean and declare myself as Ulrika 38,24,36 and I usually get my bits out when I'm on site.
You do realise that your real ID will be disregarded from now on don't you![]()
