Question regarding PFC, Ze, and live polarity tests. Please help. | on ElectriciansForums
Discuss Question regarding PFC, Ze, and live polarity tests. Please help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nazoom
When carrying out the tests: live polarity of the supply, Ze, and PFC on a TN-s single phase system, what happens to the double pole main switch? is it off or on?
Many Thanks.
I am still unsure!! So the main switch off and the test is carried out at the incoming (supply) side and not the feed? OR at the feed (outgoing) side?
Many thanks.
With the main switch off, use the live terminal on the incoming side of the main switch and the (disconnected) main incoming earth to do your Ze. If you get a reading then you have also confirmed polarity of supply, because if polarity is wrong your tester will not do the test due to there being insufficient voltage between the 'Line' and Earth.
Sent from my HTC Sensation using Tapatalk
Reply to Question regarding PFC, Ze, and live polarity tests. Please help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
