M
MattyKHZ
Being in a new build 4 bed detached that is south facing and ideal for PV I have started looking and had a few quotes and decided upon the following system:
17 x Sanyo HIT-N235SE10 Panels
SMA 4000TL Inverter
Not being good with electrics I am reading about G83 and 4000TL sometimes being refused by the DNO on a 4KW system. Mine would be 3.95KW I believe.
I have also read that you can cap the 4000TL at somewhere in the region of 3.6KW and was wondering why you would do this? Surely if you are doing that then you could use less panels or am I missing something?
Our house has a Wylex NHRS4504 consumer unit with a 80A RCD, NSB06 x 3 modules, NB16 x 1 module, NSB32 x 4 modules and NSB40 x 1 module. I believe I would either need an additional unit for the PV as I have no spares or was thinking could I get something like a 15 way Wylex Consumer Unit, transfer the modules across to it and simply pay for the extra modules needed. Reason being we are also planning a new kitchen and believe lighting and motors in the wall units may require some more power than what our existing set up provides so trying to future proof our house.
Hopefully we will get our install before the December 8th FIT changes but wanting to try and esnsure it is as smooth as possible.
We are with EDF and have already got their FIT forms.
Any advice would be welcome.
Thanks in advance,
Matt
SMA 4000TL Inverter
Thanks in advance,
Matt
