M
mjanesuk
Hi,
Had a 4kw system installed on the 3rd, and it has not gone quite how I expected. My uneasy feeling is that by now, reading this forum I might know more than the people who did the work - and that concerns me.
I will list a few issues and provide more details if you think I might have a point..
Big (I think issues)..
Your thoughts please, on any of the above
Martin
- K2 rafter mounts only secured using one bolt (all 3 that I could look at easily) - Krannach say minimum of 2 even in the 37mm fink trusses we have.
- Install manual states that the module junction box has a breather port so needs to beat the upper end of the panel once fixed to the roof (we have 10 portrait with the junction box at the lower end)
- Install manual states only secure the panel by the long edge - we have the remaining 6 secured by the short edge.
- The MD/designer stated one track of one string of 6 and one track of one string of 10 for an SB4000tl-20. I suggested the 10 needed to be split into two strings (this forum) and SMA support agreed. Should I have to design it myself?
- The commisioning involved the Spark stating "its done, I'm off". nothing about how to read/use/isolate if a problem.
- The panels appear to be a rebadged Chinese model though I was sold on the basis of them being a "good German Make" - the German company is rebadging.T
- the module cables are flapping in the wind - rubbing against the tile roof no doubt!
Martin
