Question? | on ElectriciansForums
Discuss Question? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
W
Wardy35
Question:- A conductor has a cross-sectional area of 20mm2, a length of 48m and made of material with a resistivity of 0.02 micro ohms per meter, what is its resistance?
Once i get loads of answers i will tell you why i asked it.:confused:
Regards
Mick Ward
With the information given that should be 0.96 microohm/m:confused:
ShÂŁ$, that's wrong !!!
2nd edit: micro ohms to ohms? Doesn't make sense. Is that all of the info given?
Upvote 0
The question and answer is exactly how i have it in front of me but in another book i have a similar question which is:-
Calculate the resistance of 100m of copper cable of 1.5mm squared csa if the restivity of copper is taken as 17.5x10minus9 ohms/m.
Using the formula R=pl divided by a = ohms
Therefore 17.5x10minus9ohms/m x 100 m divided by 1.5x10minus6 m/s giving 1.16 ohms
My confusion is where did the 10minus 6 come from with the csa 1.5?
Does this make sense?
:confused::confused::confused:
Upvote 0
The higher the cross section the lower the resistance. 0.02 micro ohms is a bit low that is 2 * 10^-8 Ohms !!!
So 48m * 0.02 micro ohms/m/mm^2 / 20mm^2 = 4.8 uOhm ??? :confused:
Upvote 0
Figures, the book i am working fromis the OLCI workbook which was written in 2006, i also have Trevor Linsley's Electrical Installation Work Level 2 written in 2008 and they are totally different.
:mad::mad::mad:
Upvote 0
Reply to Question? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Electrical Courses
