G
gophil5
Hi,
I have been ask to install a couple of convector heaters to a small shop.
Been on the dimplex website and a couple of 3kw WFE That are suitable.
Am after a bit of advice of installation and cable/mcb's.
Plan to install and run a radial with 13amp local fcu's. supplied from a 6mm pvc. Is it ok to supply this from one radial circuit and runoff one mcb with RCD protection? Istallation will be clipped direct through the basement to the c/u. about a run of 15metres.
Just wondering if anyone has any suggestions about this install.
