T
TPES
Just a few questions I have for the big day.
The assessor wants to see I can complete a" Minor works cert" and "Electrical installation cert" and what ever jobs i have to complete these to certs are up to me.. correct?
...Meaning the Electrical installation cert doesn’t have to be a "Major" job Like some people would first think.. So initially sparks thinking it would have to be major, like a re-wire or consumer unit change this is not always the case.. It could just be installing a single circuit like a radial or RFC. along as you can complete an EIC. is this correct ?
The jobs I have in mind are.. (MWC) an outdoor socket on my own house, directly onto the back of my kitchen wall, spurring off the RCD protected RFC... So I will need to record the supply details and do relevant tests on the RFC that feeds the outdoor socket, and this circuit alone. Wont be expected to touch any other circuits. Is this correct ?
Major Job is a Mains change on a TT Earthed system property, On this I will obviously have to test every circuit going back to the board and record results. Is the assessor going to expect me to drop every socket and FCU on ring final circuits getting a reading from every point, I know its easy enough getting readings from sockets but do i have to drop FCU's that are on the ring to also get readings?
..The same for lights. If you wasn’t to know which is the last light on the circuit will i be expected to drop every big fancy light fitting and switches no matter how long winded it is to take down the big fancy metal chandelier to then find out this isn’t the last fitting? the same with outside lights on the lighting circuits, will i need to go outside and go up ladders to drop outdoor fittings to get readings, will he want to watch me go around and do all this?
I know the assessor is only planning to be with me for half a day but if you've got a right nightmare of a job, your 2 jobs could easily take a full day if there’s a lot of work required for the tests.
Sorry if I’ve gone on I just wanted to get it all in one topic rather that loads of different topics.
If I have more questions or anyone else does I hope people don’t mind them being added to this topic
