J
Jason82
I would like to seek advice from experienced guys because I have interview test for my power engineering as below. Thank you.
a) For 600A switchboard, what type of device setting need to do? Can I say that I need to do setting for direct acting for MCCB since more than 100A and earth fault relay setting?Any other else?
b) How to calculate the earth fault setting since some use ELR and EFR with the setting range only 0.03A to 5A for the switchboard below 700A?
c) What is the sequence for electrical testing need to do for the bungalow when electrical installation completed before supply is turn on? Can I say need the test below:
earth electrode test
Continuity test
Ring final circuit test
Insulation test
d) How we apply the value of earth fault loop impedance value and earth electrode resistance value?
Continuity test
Insulation test
