N
nazoom
Hi
I have a few Questions regarding Inspection and Testing. Please be patient with me and help please! If you could answer the wrong questions for me I will be very sincere.
Q1. State the need to comply with the statutory and non statutory requirement, and guidance material for particular location and environment in which electrical installation are installed?(1.4)
My answers:
a) The work must be carried out be a competent person.
b) Must ensure the safety of workers and people.
c) Carry out work safely and install equipment in accordance with BS7671.
d) Carry out inspection safely and use correctly maintained equipment.
e) Fill in the documents correctly.
Are they Correct?
Q2.State the particular requirement for periodic inspection of an electrical installation as defined in BS7671? (2.3)
My answers:
a) For Reporting on the condition of an existing installation.
b) For inspections compromising of a detailed examination of the installation without or with partial dismantling.
c)Check on the condition of all the circuit and equipment.
d)Inspection procedures will include: Age, Corrosion, External influence, damage, and wear and tear.
Are They correct?
Q3. Sate the requirement of the Electricity At Work Regulations for safe inspection and testing in terms of those (2.5):
a) Carry out work?
My answer:
As may be necessary to prevent danger, all systems shall be maintained so as to remove danger as far as possible such danger.
Is this correct?
b) Using the installation and the building during the inspection detesting?
My answer:
It is not allowed.
Is this correct?
Thanx a million
My answers:
Are they Correct?
My answers:
Are They correct?
a) Carry out work?
My answer:
Is this correct?
My answer:
It is not allowed.
Is this correct?
Thanx a million
