T
The General
morning all.
I'm planning a job for a client which (amongst other things) includes installing a pondpump.
I've just seen the pump they've bought, and it's designed to be wired directly off a fused spur.
That's fine, but as there's also going to be power to some outdoor sockets for some other bits, my intention had been to fit a 3-pin plug (with the same rated fuse as the spur would have been) and simply plug it into the external socket.
as it specifically says in the pump instructions that it's designed to be wired in, am i doing anything wrong by fitting a plug instead?
part 2 to that question is that if I do wire it off a fused-spur permanently, how do I get continuity,R1+R2 and IR readings as it's a sealed unit at the pump!?!
obviously I can get readings up as far as the spur, but there's another 10m of cable up to the pump...?
am i just making life difficult for myself?!
as an aside - if is plugged into an external socket with 3-pin plug it stops being notifiable under part P doesn't it?
final question - is it allowable to have a fused spur coming off a fused spur?
client wanted 2 double sockets in the garage, which was going to be a fused spur.
now that I've got to put the pump on a fused spur, the spur will be coming off from one of the new sockets i was fitting in the garage!
is that okay?
sorry to ask lots of daft questions, but let's just say that the training course I was on left a lot of gaps.......
thanks in advance for your help!
is that okay?
