Quick Question about a Pump | on ElectriciansForums
Discuss Quick Question about a Pump in the Australia area at ElectriciansForums.net
K
kingofhearts
Hi there,
A new pump has been installed in a hot press and I'm going to connect it to a spur,
I'm gonna take the feed for the spur from the immertion switch, just wanna know will a 1.5mm cable be ok or will I use a 2.5mm ???
Cheers
Hi there,
Cheers
I'm not quite sure what a hot press is, but then that's probably me being thick.
Do you know the rating of the press ie 3000w or 13amps??
How are you taking the spur from the immersion switch?
Is the immersion still wired up, if so what rating is the breaker?
Cheers
Jim
Some things you will need to find out.
1. Is the immersion on it's own circuit
2. The rating of the MCB/fuse protecting the immersion circuit.
3. The existing loading of the immersion circuit
4. Existing volt drop.....how far do you intend "spurring" off to this pump
Before deciding on the cable, you need to make sure you can actually do this.
HTH.
HTH.
1. Is the immersion on it's own circuit YES
2. The rating of the MCB/fuse protecting the immersion circuit. 20A
3. The existing loading of the immersion circuit Don't Know
4. Existing volt drop.....how far do you intend "spurring" off to this pump One Foot Max
I'm sure it is possible to do this, I'm going to take power from the immersion switch to the spur and then from the spur out to the pump, afaik the pumps only pull in half an amp or so, so it should be alright
Reply to Quick Question about a Pump in the Australia area at ElectriciansForums.net
No joy unfortunately. A guy from TasNetworks came out and took a look. The line is currently too low, and they would not be able to get it to...
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
