quick question-smoke alarms upstairs | on ElectriciansForums
Discuss quick question-smoke alarms upstairs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
davelerave
dormer style house
do i need one or two alarms upstairs here
is one in the lobby beside bedroom enough?
i have 2 in entrance and corridor below
+kitchen heat and living room optical smoke
i believe that as long as the distance of an alarm is no more than 7.5 metres from the doorway of any room on that floor. so if its on the landing it has to protect all rooms off it within a distance of 7.5 metres or less. if not u will need 2.(hope that makes sense)?!
or the other option is one in each room, customer and budget decides really, thats why min requirements are usually on escape routes like hallway and landings etc.
OSG or Aico website for info.
i'd be inclined to put 1 in the games room. and wtf is hot press, is it where they print the Daily Sport?
Depends if it's a new build or rewire. If it's a new build a LD2 system is required so optical alarms within 3m of all bedroom doors and at the head and base of all staircases. Additional smoke and heat alarms should also be fitted in areas of increased risk of fire. As a rule of thumb this would be a smoke alarm in the lounge (or similar room with lots of electronic gear in it) and a heat detector in the kitchen on top of the main escape routes. If it's a rewire a LD3 system is required which involves optical alarms along the escape route only so again within 3m of bedroom doors and at the head and base of all staircases. Worth having a look at the Aico site, plenty of good information there but worth reading Approved Document B too for all the information you'll need.
Whats floating in my diminishing memory cells is a maximum distance of 3 meters from any bedroom
Not sure why its floating there,it probably comes from that building reg book that is as shiny and unspoilt as the day I got it
Bet I'm wrong on this though :eek:
3 metres from a bedroom door is the max- afaik
top of staircase is less than 3m from bedroom door -but i'm wondering if the door 'between' alarm and bedroom door means an extra alarm is needed in lobby?
The distances must be, as they are, so that they are heard by the folks in the bed. and enough decibells to boot
So at a guess the door between would make that more difficult to justify not having another
I should really read up on this before doing this guesswork and posting what could be claptrap :)
One in lobby and one in landing. Thus you have one within 3m of each bedroom door (it's a bedroom, even if you call it a games room). You won't meet the sound level requirements otherwise.
true-games room/bedroom same thing;) prob from a rules point of view
i could fit one less than 3m from each bedroom door
but as there's a door in between i'll go with 2
u not wrong des!!!!!!..................think i will double check before posting late at night! info was on page 16 of approved doc B 1.15A Im not sure?!.......am i looking in wrong place too?
Reply to quick question-smoke alarms upstairs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
