quick question
W
waynelester
i have a wall heater to install,the three core flex connected is coloured blue,brown and black.im assuming the black is earth,thanks
Get a muti meter and check that there is continuity from the end of the black wire to the casing of the heater. You are probably correct, but don't assume or take my word for it. Do you have the installation instructions?
