L
Lukethoma1985
Hi everyone, how are you all
Just a quick question, im quite new to the trade.
Recently my brother had the local electrical contractors around which work for the council.
Theyve upgraded the consumer unit and had to check everything. His got electric goin to the shed fed off a 32A mcb, 6mm t+e to a cooker switch with socket. Which then is wired to a fuse spur. From the fuse spur in 2.5 t+e to a couple of sockets then to another fuse spur to feed 1 light.
Now is this ok as tge contractors said to my brother it was or am i just over the top.
If i was checking this, would i be right to say the circuit labled cooker, would be changed to outhouse. The cooker socket removed and the 6mm carried on through to the outhouse which the feeds a small consumer unit. Also i dont think you can run a fuse spur off another fuse spur can you?
Its boggleing my mind
Please help thankyou luke.
I hope you all have a good weekend
