Quick question | on ElectriciansForums
Discuss Quick question in the Australia area at ElectriciansForums.net
Hi there, I was wondering might anyone be able to answer a few of these questions that I cant find an answer:
- Firstly with switch start fluorescents do I use the 1.8 correcting factor when calculating the total load? Why is this?
- does the correction factor apply for digital ballasts as well?
- Does this correcting factor also apply for any other type of fitting such as SON / Metal Halide?
cheers
discharge lighting is highly inductive and even though the lamps are rated in watts the whole unit should have a VA rating.
its this VA rating that the current is calculated.
if no VA rating is given then a value of 1.8 is used to calculate it from the wattage. so its watt x 1.8 = VA.
circuits can then be calculated from this
Final circuits for discharge lighting must be capable of carrying the total steady state current, i.e. lamp current plus any associated control-gear current including their harmonic currents.
Where more accurate information is not available, the demand in VA is taken as the rated lamp W multiplied by =>1.8. The 1.8 multiplier assumes a power factor of not less than 0.85 lagging and takes account of the control-gear losses and harmonic current.
Reply to Quick question in the Australia area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
