quick yes or no | on ElectriciansForums
Discuss quick yes or no in the Australia area at ElectriciansForums.net
i always use a key switch as the isolator for a PIR but another way is to install a fused spur at high level in the room to isolate the lighting circuit and associated controls such as PIR or fan etc
Reply to quick yes or no in the Australia area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
isolation for reasons of safety could be a contactor that cuts the supply to a machine when a stop button is pressed it couldn’t be said to be...
