Afternoon all
I’ve just hooked up a couple of quinetic switches (one being the in line built-in receiver, QURS1W) to a (Vtac) 50w LED floodlight and part of the array remains dimly lit when it is switched off. Now it more than meets the minimum wattage (5w) so i’m assuming it’s a simple compatibility problem with the receiver. Assuming i’m not missing something (?), can anyone kindly recommend a floodlight that IS compatible? Quinetic floods, as far as i can tell, all come with built in receivers which i don’t need ....
Truly grateful for any help
