Can the quinetic 2 x 6amp controller control 2 separate loads if I buy 2 separate key fob switches?
1 load will be decking lights And the other will be wall lights.
I cant find the info anywhere that says if the 2 loads on the same controller can be set up for different loads or if I would need to buy two 6 amp controllers and 2key fobs.
thanks
thanks
