Quinetic switch advice | on ElectriciansForums
Discuss Quinetic switch advice in the UK Electrical Forum area at ElectriciansForums.net
Fife
Hi All,
looking for some advice from anyone that knows about the Quinetic wireless switch.
light currently on a traditional 2 way switch, looking to make it 2 way, but the second switch will be bottom stairs. Cable were run into artic but never used, havent a clue why.
house is an old with lathe and plaster, so don’t want to upset it too much as recently decorated.
question is do Both light switches need to be quinetic wireless or can the receiver be connected, whilst still using the original traditional switch.
electrician not really keen due to running cable. But will do do if can do it with one wireless, he don’t really know bout them hence why I am researching.
appreciate any help or advice.
Lost me a bit mate, are you asking if one switch can be traditional cable fed and one can be wireless??
Yes thanks exactly what I am asking
[automerge]1593553026[/automerge]
The receiver requires a neutral. It can be configured as you say with a bit of adroit wiring, but why would you do that it defeats the purpose of the switch? Do you have a neutral at the switch?
I believe the sparky said there was.
Reply to Quinetic switch advice in the UK Electrical Forum area at ElectriciansForums.net
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
