Quinetic wireless kit (can it be used with photocell) | on ElectriciansForums
Discuss Quinetic wireless kit (can it be used with photocell) in the UK Electrical Forum area at ElectriciansForums.net
London
Hi looking at the Quinetic kit for some outside lights, not used this many times, looking at the receiver and switch, is there any way I can incorporate a photocell with this?
supply L & N to the receiver from the photocell. so you have feed to photocell, then after dark feed to receiver, only then will the switch activate the light.
I would do it the other way round and provide the receiver with the permanent power. Depending on which receiver you use it may require permanent power (the WiFi enabled units for example). I'm not sure how long the receivers retain any data without power for long periods.
That ok? Was having a moment
[ElectriciansForums.net] Quinetic wireless kit (can it be used with photocell)
probably a better way. trial and error maybe useful.
[automerge]1568187149[/automerge]
looks like the receiver will override the ptotocell done like that. you need to feed Lout from receiver to photocell, then to lights.your pic shows S/L from receiver directto lights.
I think the second version would be ok. The receiver controls everything downline from it. Never used Quinetic with a photocell though, but i think it would work...basically, power up the receiver with the switch, and then the photocell acts as a secondary switch. Coincidentally, I was doing a demo with my Quinetic demo kit this morning. It has been in its box for at least 6 months without any power to it, and the switch did not need to be paired again, it just worked...out of the box, so to speak.
Reply to Quinetic wireless kit (can it be used with photocell) in the UK Electrical Forum area at ElectriciansForums.net
It often works for me 🤪
https://www.tlc-direct.co.uk/Products/QUPIR.html?source=adwords&ad_position=&ad_id=&placement=&kw=&network=x&matchtype=&ad_type=pla&product_id=QUPI...
