G
Gaz82
Would appreciate it if someone could tell me if this quote seems about right. I am a first time buyer close to completing on a 3 Bedroom Semi Detached house and building survey came up with the rewiring red flag (property built in 1964). I then had someone out to do a visual, and following this seller has paid for ECIR. The asking price is now being dropped to reflect the quoted fee for rewiring so in theory I shouldn't be out of pocket.
The electrician says the work can be done over a weekend period. The quoted amount is £1825 and the location is SE England (Kent). The house is currently empty and vacant.
Kitchen
- Re-wire the feed to the back porch lights
- Switch drop re-wire
- Connect earth in existing fittings
Living Room
- Re-wire switch drops x2
Downstairs Toilet
- Complete re-wire
Front Porch
- Complete re-wire
Downstairs Hallway
- Re-wire the two switch drops for landing lights
- Re-wire thermostat
- Re-wire the stair-light
Upstairs
- Upstairs bedrooms x 3 switch drops in each room
- Re-wire switch at the top of the stairs
- Re-connection of earth on to downlights and change for fire rated downlights
- Re-wire boiler room light switch drop
- Change the fuse board
- Change downlight above bath to IP rated (water resistant)
- All wooden switch boxes will be replaced for metal flush boxes
The above works includes all materials, making good of chases, holes and painted to original condition.
***Not sure if relevant but I plan on having a lighting design element as part of the revamp of the house - should I mention this now to the electrician even though I haven't had an appointment with the light designer yet?***
Kitchen
Living Room
Downstairs Toilet
- Complete re-wire
Front Porch
- Complete re-wire
Downstairs Hallway
Upstairs
