Quotes for inspection & testing | on ElectriciansForums
Discuss Quotes for inspection & testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
Test Probes
Hi all. Does anyone know what the going quote is for inspecting and testing a consumer unit or even a 3 phase DB? I know some companies quote by the circuits to be tested.
Wendell Martin
Thanks telectrix for the info. So if you were to test 2 circuits on a sigal CM then the minimum would be 125. Is that write?
Wendell
£20-£30 a circuit is the going rate round my way to, well that's what I charge anyway with a minimum of £120.
Does that include tracing? I work mainly on industrial/commercial , and tracing times can sometimes not be calculated on a quote , hence
the price per circuit and the tracing extra.
probably works out at same price?
Sort if like asking how long is a piece of string.
I always provide a free quite having visited premises so I know what I'm letting myself in for. I then price per circuit with an adjustment, if necessary to reflect state of installation
£15-£25 per circuit for me. For larger, more complex installations allow room for tracing of circuits, no access to certain areas, dealing with snobby solitaire playing office types who can't live without their PC for five minutes etc.
Reply to Quotes for inspection & testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That's a glass half full thought 🤔
2 3
