R1+R2 and ZS results | on ElectriciansForums
Discuss R1+R2 and ZS results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
pencilpusher
I have measured the highest R1+R2 on a lighting circuit as 1.51 ohms at a switch. However, I get 0.86 ohms on a ZS test at the same point. I am on TNCS system and my Ze is 0.22 ohms. Although I expected a lower ZS by measurement than by calculation, I did not expect it to be this low. I understand parallel paths will lower it but by this much?
Views please.
Thanks PP
estimate the cable length. that 1.51ohms for 1.0/1.0mm would indicate a cable run of 40m. if it's 1.5/1.0mm, even longer ( i don't have the figure to hand). seems a bit high.
edit: 1.5/1.0mm a res. of R1+R2 of 1.51ohms would indicate a circuit length of approx 60m.
Its 1.5/1.0 and it is no way near 40m. It is an unusual reading compared to the others around the place. I would say 10m tops. Loose connections somewhere?
EDIT: Even so, why the much lower ZS with the 1.51 ohms R1+R2?
Thanks PP
think its your R1+R2 is out. 10m should be 0.3ohms. leads not nulled properly or a high resistance connection, not seen on the Zs test.
When I tested R1+R2 by removing the conductors from the switch, I still got 1.51 ohms, ish. I don't understand why bad contacts are "not seen" when a ZS test is done either tbh.
maybe the fact that the Zs test is a live test with 230v on the circuit. continuity testing is done at 12v or less.
remember that on a 2 way curcuit, your R1+R2 is through 2 closed switches. this could be as wp says. also, it's common for the 3core between the switches to me 1.0mm, not 1.5mm.
There must be something up with the switch drop. I had about 0.68 ohms at the light point on a two way circuit. Mmm
Excellent point. I will try testing without switches and see what I get. Mind you, the ZS is fine and that's the main thing I suppose.
what you could do is link out the switches and read again for R1+R2. if the reading drops, then you've proved it.
Reply to R1+R2 and ZS results in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
