R1+ R2 reading | on ElectriciansForums
Discuss R1+ R2 reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
markb
I got a reading of R1+R2 for an outside twin socket of 0.06 ohms where i ran from c/u 2.5mm T+E to adapator box outside using 2.5 3 core swa just need to know if this reading is ok.(TNS)
The reason being is done the same on another house and the R1+R2 showed 0.31 ohms for socket.
It's more than Ok. Better than your last job. Why wouldn't it be O.K? Ensure you carry out an ELI also, and if it's a new circuit from the C/U it would require a domestic installation certificat. GOOD LUCK.
Reply to R1+ R2 reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
