r1+r2 readings | on ElectriciansForums
Discuss r1+r2 readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
Benjamiin
Im sure this has been covered before, but Im after peoples views, I am 100 percent confused by the reg that states zs may be calculated using ze plus r1 r2, but r1 r2 cannot be calculated using zs minus ze, naturally I test my r1 r2 and zs. But once I've tested my zs on a periodic for example I have already proved there is an earth or continuity of it at the end of line, so why the big dramas over not being allowed to do it?
this is because R1+R2 should be a dead test, done before the circuit is energised. and what the hell r1 and r2 have to do with it i don't know as they are end/end resistances of a RFC.
Zs = Ze +(R1+R2) because you're measuring all those things in isolation.
Zs is measured including parallel paths
No, sometimes I forget to press it either because I'm a dumbass or because I've been on the lash all day :)
I have done it loads in the past....but as tel was having ago at the op for it, I couldn't resist..lol
How was the wedding the other week??? Sheilds was packed....we went to the roman fort...not my cup of tea but my lad liked it.
What else would you like to know about? We can take any thread off topic as far as you want to be taken.
EG
Greggs pasties are crap, discuss.
Reply to r1+r2 readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
The actual listed observations seem easily resolvable, comfortably less than a day's work. The picture of the supply poses a few questions...
