r1 r2 rn ring test problems | on ElectriciansForums
Discuss r1 r2 rn ring test problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
brightspark08
Hi all Im new to this site so bare with me if im in the wrong place, Your help would be very much appreciated,
I have a ring main in a house and im testing r1 r2 rn,
I get 0.48 ohms on r1 0.48 ohms on rn but also get 0.48 ohms on earths, which is wrong as it should be 1.67 times that of r1 and rn i have been round every socket and all connections are tight,
it is 2.5 twin and earth with 1.5 earth wire not 1.0 earth wire,
Wouldnt worry about it prob Supp bond, heating etc creating a par path - providing ir and zs is ok
If it had a 1mm cpc readings would be 2.5 greater not 1.67 although im sure you already know this
Reply to r1 r2 rn ring test problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
