R1 R2 test for GU 10 Class II lights - Info | on ElectriciansForums
Discuss R1 R2 test for GU 10 Class II lights - Info in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chrisgc
When it comes to obtaining R1+R2 on lights (GU 10, Class II type) is there a work around solution without removing downlight fittings (due to decor/ceiling being messed up)?
Can be taken by dropping the furthest fitting and testing at joint box, but as farm electric said, must be furthest point.
Wander lead wont provide r1+r2 result.
Edit. Just noticed op said without dropping fitting. Apologies
Reply to R1 R2 test for GU 10 Class II lights - Info in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The actual listed observations seem easily resolvable, comfortably less than a day's work. The picture of the supply poses a few questions...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
