R1+R2 TEST. Tester clicking over and over | on ElectriciansForums
Discuss R1+R2 TEST. Tester clicking over and over in the UK Electrical Forum area at ElectriciansForums.net
North Yorkshire
Have only recently gotten in to testing. Doing an R1+R2 on a lighting circuit but instead of producing a result my tester clicks over and over again. Any advice please? Thank you.
Check the circuit is dead first.
use a multimeter to see if you have indeed got the right cables and you do have some continuity between live and earth.
Reply to R1+R2 TEST. Tester clicking over and over in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
