R1 & r2 | on ElectriciansForums
Discuss R1 & r2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
East London
Hi, just started my level two 2330 and found this web site while doing some research for homework. I can seem to find the answer to the following question: Which conductor from R1 or R2 is broken through the protective device? I think it is R1 is this correct? Thanks
Hi.
R1 = line conductor
R2 = Circuit Protective Conductor (CPC)
Rn = neutral conductor.
So yes the R1 (line) conductor is broken by the protective device under fault/overload conditions.
Reply to R1 & r2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
No worries.
