R1+r2 | on ElectriciansForums
Discuss R1+r2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Regs
essex
If i you can't isolate the supply to obtain an R1+R2 would it then be acceptable to calculate it?
Also then as an alternate means how would you prove polarity?
You calculate R1 + R2 at the design stage using resistance values of used cable and circuit length. If you cant isolate you cant do a "dead" test and would carry out a Zs test for earth continuity and polarity
Reply to R1+r2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
Also,if you had a duel box with a lighting cct on one side you would get a false reading.
