P
Peter Woodford
Guys,
not done formulas in a very long time and need to get back into it. If I have a Zs 0f 0.48 ohms on a 230v supply how do i work out the R1 + R2 value. if poss can you send me the working outs on how to do this.
thanks in advance
If Zs was obtained using a loop impedance tester then it would include parallel paths, and give a lower value than Ze+R1+R2.
I suppose in theory you could loop test at the board with bonding still connected, then deduct Zs from that figure.
This is not what I would do, but just offered it for discussion.
The correct way would be taking the live out the MCB, put it on the earth bar and measuring at the other end of the circuit.
You need to know the Ze which will be deducted from the Zs to leave the R1 + R2 value
ZE + (R!+R2) = Zs
You formulas missing the F factor (1.2) for 70 celcuis PVC
if designing the circuit the Zs design = to Ze + F(R1+R2) where Ze is 0.35 TNC-S or 0.8 TN-S and F = 1.2 (pvc conductors table 9C on site guide)
As well if you performing a periodic inspection and are unable to measure Zs the you can measure R1+R2 and then Ze, then finally Calculate the ZS for direct comparison with BS 7671:2008 usind the following formula
Zs calculated = Ze measured + 1.2(R1 +R2 measured) ( this is known as the summation method)
Personelly be told Zs-Ze does not = R1+R2 nor should it ever be used as a short cut to actual testing.
Guys,
thanks in advance
Peter have a read of GN.3 Appendix B, there are a number of worked examples that may be useful near the back of the book.
R1 + r2
Thread Tags
Peter Woodford,
chocolate,
