R2 | on ElectriciansForums
Discuss R2 in the UK Electrical Forum area at ElectriciansForums.net
glasgow
Hi, am looking for some help. I know r1+ r2 is connect phase to cpc at cu and test between each at skt, sw etc on low omhs, what i cant seem to get is just r2 can anyone help?
R2 is just the cpc that you are checking,
It's a good way of checking that metal lights and switches have been earthed.
Connect your wander lead to the earth terminal inside the board, one probe of your meter to the wander lead and the other probe for testing. As previously mentioned don't forget to either null the lead out or subtract the reading
'wander' round the house testing till your hearts content
good for finding the furthest point as well (if not obvious, 3 plate n all that)....then you can get an R1 R2 from there.. for EICRs..
Reply to R2 in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
I believe that it is incorporated into the 5 days. But will double check. Thanks.
