R63 spot lights blowing | on ElectriciansForums
Discuss R63 spot lights blowing in the UK Electrical Forum area at ElectriciansForums.net
R
Russ1109
Hi,
Customer complaining that bulbs are blowing. Fitting is a 3 x spot with 60w R63 spots.
Tells me he was having problems previously so got the fitting changed and apparently has only had 3-6 mths use.
Fitting is only a cheap plastic type. As this fitting has recently blown 2 bulbs he asked me to look at the wiring.
Checked out today and light is linked to a 5ft floro at other end of kitchen on same switch . Checked cable,connections,checked voltage, all fine,Lamp holders in spot fitting all look to be fine.
He replaced the fitting with 3 lamps this afternoon. Switched light on tonight and 2 lamps blew so has phoned to tell me
Throw fitting and get sumat decent or wot? Anybody else had issues with fittings blowing lamps.I'd told him not to use about cheap lamps.
Couldn't be anything to do with the capicitor on the flouro could it?
Reply to R63 spot lights blowing in the UK Electrical Forum area at ElectriciansForums.net
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
