Ra For earth rod | on ElectriciansForums
Discuss Ra For earth rod in the Australia area at ElectriciansForums.net
B
Barker
Hello, can any oy you Brighter Sparks tell me how to get the Ra measurement for an earth rod using a Meggar 1552.
Cheers Alex
Switch off all supplies via main switch at DB, remove main earth (to rod) at DB and do a loop test between the live supply side of the db and main earth (to rod) this will give you a Ra value for the rod.
I hope this makes sense
Reply to Ra For earth rod in the Australia area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Thanks for the advice! Much appreciated
